2 years 3 months ago - 4 months 3 weeks ago
Latest firmware as of 05/07/26 here
station-drivers.com/index.php/en/forum/e...-34-11?start=45#6542
  • AOnurY
  • AOnurY's Avatar
  • User
  • User
Re: RTL9201 Firmware?
2 years 2 weeks ago
  • Pablo_24
  • Pablo_24's Avatar
1 year 11 months ago
Hi,  Shonk , i try this firmware and works correct with my RTL9201R-VB-CG.
RTL9201(R)v1.32.7z
PID : 0x9201
PRODUCT : "RTL9201"
SERIAL : "012345678942"
SCSI_PRODUCT : "RTL9201         "
DISK_HOTPLUG : n/a
PINMUX1 : n/a
PINMUX2 : n/a
U2_MAXPWR : n/a
U3_MAXPWR : n/a
ASPMDIS : n/a
DISK_IPS_THRES : n/a
CUSTOMIZED_LED : 41 00 00 00 00 00 00 00 00 00 00 00 00 00 00
UART_DBG_PIN : 0x64
FW Ver : 9.32.74
FW Build Date : 2023.07.17
IC Pkg Type : SATA
  • mizoarc
  • mizoarc's Avatar
thank you
thanks where did you find it
Time to create page: 0.032 seconds
