il y a 1 an 11 mois
Hi ok I will remind you that there are risks in updating the firmware, thanks for all the information
- hu4567
il y a 1 an 11 mois
@QuadDamage Well ok, something is indeed strange with 1.5.42.
After the update it survived a reboot without a problem, but not a power off & power on.
So, for now I will go back to 1.3.33 (with ASPM) and test the other 1.5.x versions later again.
This is my 1.3.33 image: www.dropbox.com/scl/fi/okyhfc7c73m08baty...30e&st=qiogb195&dl=0
The rest of the 1MB flash is filled with 0xff.
Les utilisateur(s) suivant ont remercié: QuadDamage
il y a 1 an 11 mois - il y a 1 an 11 mois@QuadDamage Well ok, something is indeed strange with 1.5.42.
I flashed this to my card earlier with flashupdate2 --reflash ATL2-8.0.1_AGENT_sign.CLX hu4567.clx
it flashed fine mac is preserved suspend and wakeup still fine
power off still fine
what exactly is different to this in comparison to the original file
as i have tried flashing via this method in the past and there is no link after suspending the pc or powering it off
flashed my second card also mac also preserved
thanks btw..
you need secure boot disabled to flash
i had turned it on the other week and was getting an error until i disabled it in the bios
G:\1>kickstart2
Chip reset completed (boot from flash). Time: 60 ms
Loaded MAC FW Version: 1.0.113
Loaded bundle: 1.3.21
G:\1>flashupdate2 --reflash ATL2-8.0.1_AGENT_sign.CLX hu4567.clx
flashUpdate2 x86_64-w64-mingw32-4.10-110-g0d62bf7
Starting hostboot (requested by user)...
Chip reset completed (boot from host). Time: 391 ms
Success load UpdateAgent
ERASE start
ERASE finish
REFLASH start
Request for fragment 0x00000000:0x00002000
Request for fragment 0x00002000:0x00004000
Request for fragment 0x00004000:0x00006000
Request for fragment 0x00006000:0x00008000
Request for fragment 0x00008000:0x0000a000
Request for fragment 0x0000a000:0x0000c000
Request for fragment 0x0000c000:0x0000e000
Request for fragment 0x0000e000:0x00010000
Request for fragment 0x00010000:0x00012000
Request for fragment 0x00012000:0x00014000
Request for fragment 0x00014000:0x00016000
Request for fragment 0x00016000:0x00018000
Request for fragment 0x00018000:0x0001a000
Request for fragment 0x0001a000:0x0001c000
Request for fragment 0x0001c000:0x0001e000
Request for fragment 0x0001e000:0x00020000
Request for fragment 0x00020000:0x00022000
Request for fragment 0x00022000:0x00024000
Request for fragment 0x00024000:0x00026000
Request for fragment 0x00026000:0x00028000
Request for fragment 0x00028000:0x0002a000
Request for fragment 0x0002a000:0x0002c000
Request for fragment 0x0002c000:0x0002e000
Request for fragment 0x0002e000:0x00030000
Request for fragment 0x00030000:0x00032000
Request for fragment 0x00032000:0x00034000
Request for fragment 0x00034000:0x00036000
Request for fragment 0x00036000:0x00038000
Request for fragment 0x00038000:0x0003a000
Request for fragment 0x0003a000:0x0003c000
Request for fragment 0x0003c000:0x0003e000
Request for fragment 0x0003e000:0x00040000
Request for fragment 0x00040000:0x00042000
Request for fragment 0x00042000:0x00044000
Request for fragment 0x00044000:0x00046000
Request for fragment 0x00046000:0x00048000
Request for fragment 0x00048000:0x0004a000
Request for fragment 0x0004a000:0x0004c000
Request for fragment 0x0004c000:0x0004e000
Request for fragment 0x0004e000:0x00050000
Request for fragment 0x00050000:0x00052000
Request for fragment 0x00052000:0x00054000
Request for fragment 0x00054000:0x00056000
Request for fragment 0x00056000:0x00058000
Request for fragment 0x00058000:0x0005a000
Request for fragment 0x0005a000:0x0005c000
Request for fragment 0x0005c000:0x0005e000
Request for fragment 0x0005e000:0x00060000
Request for fragment 0x00060000:0x00062000
Request for fragment 0x00062000:0x00064000
Request for fragment 0x00064000:0x00066000
Request for fragment 0x00066000:0x00068000
Request for fragment 0x00068000:0x0006a000
Request for fragment 0x0006a000:0x0006c000
Request for fragment 0x0006c000:0x0006e000
Request for fragment 0x0006e000:0x00070000
Request for fragment 0x00070000:0x00072000
Request for fragment 0x00072000:0x00074000
Request for fragment 0x00074000:0x00076000
Request for fragment 0x00076000:0x00078000
Request for fragment 0x00078000:0x0007a000
Request for fragment 0x0007a000:0x0007c000
Request for fragment 0x0007c000:0x0007e000
Request for fragment 0x0007e000:0x00080000
Request for fragment 0x00080000:0x00080300
REFLASH finish
OSB dump:
state: 1
avalability: 0x00000070
error: 0
chipId: 0x00B1A113
ecid: 0x6BA13E26 0x61141553 0x480001A8
flashSize: 0x00200000
activeNcb: 0
epoch: 0x00000000
control: 0x00020000
pkHash: 0x00000000 0x00000000 0x00000000 0x00000000
Status: Success
G:\1>kickstart2
Chip reset completed (boot from flash). Time: 100 ms
Loaded MAC FW Version: 1.0.121
Loaded bundle: 1.3.33
- hu4567
il y a 1 an 11 mois
It is the AQC113-DirtyWake_Bx_ASPM_Enabled-1.3.33_bdp_aqsign.clx image file, but already patched with customclx2.
And I used the mac und phy values from entry id 8 (which uses image AQC113-Antigua_Bx-1.3.33_bdp_aqsign.clx, but I wanted ASPM).
I added this additional entry to my updatedata.xml:
(and of course, also changed "--update" to "--reflash"... very important...)
<bdp id="15">
<hwids>
</hwids>
<mac>01000c0040000000000000000100000002000c00000300003ddb9ca1ffffffff</mac>
<phy>0301040200e4030003001cc482b1ffff1dc482b1ffff1ec40100ffff</phy>
<exprom>True</exprom>
<image>AQC113-DirtyWake_Bx_ASPM_Enabled-1.3.33_bdp_aqsign.clx</image>
</bdp>
can you release a zip with every file edited and ready to go with a command
e.g. ini's edited and it will patch the clx on the fly
i dont want to miss anything
and maybe a txt file in there saying what was changed in what file
actually i think i know everything you done
i will make one and try it myself after dinner
