  • Portrait de Laroldski
il y a 2 ans 2 mois
I'm trying to update the firmware of my enclosure that use's an RTL9220 controller and I'm using firmware v1.32.78 and when I try use a .cfg file I made myself it won't work and also the firmware updating tool by Realtek delete's the information that's on the file after it try's and fails to update my enclosure.
I copied the configure file from the enclosure before I updated it and save what was on it,I have ever updated my enclosure before so the information is untouched.
I also used the included .cfg called RTL9220_LED0.cfg and my enclosure pass's with that file which also has way different setting's.
This is my enclosure.
[url] www.aliexpress.com/item/1005006754982743...in.53.41961802dtKWaa [/url]
This is my enclosure's untouched configuration file can someone look at it and tell what the problem is.
Device : [Port8] : Realtek RTL9220 #0
PID : 0x9220
PRODUCT : "RTL9220"
SERIAL : "012345678910"
SCSI_PRODUCT : "RTL9220         "
DISK_HOTPLUG : n/a
PINMUX1 : n/a
PINMUX2 : n/a
U2_MAXPWR : n/a
U3_MAXPWR : n/a
ASPMDIS : n/a
DISK_IPS_THRES : 0x01
UART_DBG_PIN : 0x64
UART_BAUD_RATE : 0x0000e100
SCSI_WP_PIN : 0x0b
SUSPEND_DISK_OFF : 0x07
PERIPH_API : 0x01
FW Ver : 1.32.82
FW Build Date : 2023.08.11
IC Pkg Type : PCIE/SATA SD
  • TheGiolly
  • Portrait de TheGiolly
il y a 2 ans 2 mois
Follow the instructions in my post to restore the original configuration
station-drivers.com/index.php/en/forum/e...-1-xx?start=265#2012
Les utilisateur(s) suivant ont remercié: Laroldski
  • Xxyyzz
  • Portrait de Xxyyzz
il y a 2 ans 2 mois - il y a 2 ans 2 mois
Version 1.33.44.011824 problems.
Smart does not work.
Trim does not work.
(Works very well with 1.32.49)
RTL9210B, ORICO M2PJM-C3, RPI-4
  • Absent
il y a 2 ans 2 mois
The firmware only works on the RTL9220VA chipset, I don't know if yours is the RTL9220A or others.
  • Xxyyzz
Ok
