- cyberops
il y a 3 ans 6 moisI use RTL9210BThis Github issue is for RTL9210 revision A. Revision B is not affected by this issue.
So, which USB enclosure chipset do you use? RTL9210 or RTL9210B?
EDIT: my bad: github.com/raspberrypi/linux/issues/4130...uecomment-1272172747
il y a 3 ans 6 mois
- Alien Invader
il y a 3 ans 6 mois
Good Evening to all! Anyone else having trouble getting the 9210B (unionsine MD202) recognizing SM2263XT nvme drives ? My intenso premium nvme 1tb cannot be detected at all, tried 3 different firmwares without any luck. The other NVME I have around with RTS5765DL works just fine and btw I'm using the latest 1.32.49 from this thread!
- cesarjapa79
il y a 3 ans 6 mois
Hello! I’m new in this forum. Sorry for my bad English.
I have the Orico M2R2-G2
[url] www.orico.cc/usmobile/product/detail/id/7775.html [/url]
try to upgrade for the version 1.32.49.140423 and my RGB gone, and Windows says that my
drive is write protect.
anyone can help?
anyone can help?
il y a 3 ans 6 mois - il y a 3 ans 6 mois
Have you saved your configuration before to reconfigure it with the new firmware (activation of RGB LEDs, activity of the disk LED, ...)
