ssd Asmedia ASM-2364 NVMe/USB 3.2 Controller firmware Version 230927_91_00_00
  • Julia
  • Portrait de Julia
il y a 6 mois 2 jours - il y a 6 mois 2 jours
#3642
@Shonk,
I have set everything apart from Idle Time (the setting in the ini is ignored for some reason)
Set:
[usb_config]
standby_timer=3
#3644
the setting in the ini is ignored for some reason and it never goes to sleep
i use the pulldown to change it to 10 mins
and now power management works for me
the flash tool is slightly newer than when i tested this
so maybe its fixed in the tool i havnt checked
but i do it anyway to ensure power management works
  • Portrait de admin
il y a 6 mois 1 jour - il y a 6 mois 1 jour
#3645
My antivirus blocked the MPTool and since then, despite my research, it has been impossible to remove the ban.
#3646
  • H3li03
  • Portrait de H3li03
il y a 5 mois 1 semaine
#3810
Hi there, I have a sandisk extreme enclosure with the same chipset, I was hoping to be able to flash a generic firmware to be able to use any nvme drive with it, cause with it's firmware, the device only recognize sandisk drive included...
I tried opening the flasher, but it seems it can't find the device from usb list, I was able to dump the firmware with asm firmware reader, the file name is asm_fw_181206_81_E3_08.bin
any idea?
thank, and sorry if it's a dumb request.
