- spike_V_sky
il y a 4 mois 2 semaines
@Shonk
Do you know what is fixed for this fw version ?
About the issue you had with the enclouser is specific of the PM9B1 ?
hi, i have the same enclousereAS_PCIE_230927_91_00_00.bin (2 of my devices came with this firmware)
Directly Dumped from my Samget Enclosure (ASM2364)
il y a 3 mois 3 semaines
its specific to the PM9B1 and is the same with any ASM2364 firmware
- Stasiz
il y a 3 mois 1 semaine - il y a 3 mois 1 semaine
@Shonk
Thanks!
I have successfully updated ORICO-M233C3-G4 with ASM2362 to AS_PCIE_230927_91_00_00.bin
Thanks!
- spike_V_sky
il y a 2 mois 4 semaines - il y a 2 mois 4 semainesworks fine here, thanks for share.@ShonkDirectly Dumped from my Samget Enclosure (ASM2364)AS_PCIE_230927_91_00_00.bin (2 of my devices came with this firmware)
Do you know the thickness, and thermal characteristics of the thermal pad provided in the package with the enclosure, in case I need to replace it ?
My enclouser at idle report 35°C, seem a bit hight ....
Its just your usual generic china 5 W/mk pad at a guess 1 or 1.5mm you need as thick as it takes to close the enclosure with a slight bit of pressure but not to much
to thin and it wont transfer the heat
35°C is fine its in an enclosure not a huge pc with airflow 75°C is high
MY Axe Speedy+ 1TB usb stick is 63°C at idle that thing is hot
your cooler than all of my ssd's in my main pc which has 6 140mm case fans
and a small fan blowing over the ssd's
Intel Optane 900P 480GB 39°C M.2
Intel Optane 900P 480GB 36°C U.2
Samsung 990 Pro 4TB 42°C M.2
Samsung 990 Pro 2TB 41°C M.2
Samsung 990Pro 2TB 43°C M.2
Samsung 980Pro 2TB 43°C M.2
AXE Speedy+ 1TB 63°C USB Stick
Les utilisateur(s) suivant ont remercié: spike_V_sky
