il y a 2 mois 3 jours
Hi I tried with the latest firmware 230927_91_00_00. Same problem impossible to make it work on a USB 3.2 X2 port (20GB)
The disk even blocks my USB ports on all of them, I thought about the case so ordered another one (Orrico) and the same the ASM2364 chip has a problem on some disks surely.
I tested my Ugreen 40GB (ASM2464) on the same port and it works at 20GB without problem
il y a 2 mois 2 jours
Is this in an amd board i have heard of a few people with amd chipsets having problems with asm2364
no problems here on z690 + z790
il y a 2 mois 2 joursConfiguration
is it a usb 4 port
what motherboard model?
il y a 2 mois 2 jours - il y a 2 mois 2 jours
Yes from Thunderbolt4/USB4 the ASM2364 only works on the USB/Thunderbolt of the Z890
Gigabyte Z890 AORUS MASTER
I think there is a problem between the USB 3.2 chipset of the Z890 and the ASM2364
