il y a 2 mois 1 jour - il y a 2 mois 1 jour
Encapsulation of USB 3.2 x2 is different to usb 4/thunderbolt
max speed is 10gbps with raw usb packets unless you handshake a pcie tunnel for thunderbolt/usb4
- 2 x Intel® Thunderbolt™ 4 (USB Type-C®) ports on the back panel
*Support up to 40Gbps with Thunderbolt devices
*Support up to 20Gbps with USB4 devices
*Support up to 10Gbps with USB 3.2 devices
It's weird because on my X670 & Z790 I had no problems with a USB 3.2 X2 (20Gb) port?
Z790 Supports native 3.2 Gen2x2
ASMedia do some USB4 chipsets that add in support for 3.2 Gen2x2 (not part of the usb 4 standard)
i presume your X670 had one of said ASM USB4.0 Chips
by the looks of it intel didnt add backwards support for it
i dont know for sure as i dont have Z890 but thats what it looks like to me
Yes on the X670 the ITE87xx chipset will manage the external USB 3.2 X2 port
I even noticed increased performance in USB4/Thunderbolt (ASM2464) compared to the X670
The fact that it is native to the Thunderbolt/USB of the Z890 chipset allows for increased performance
