il y a 6 mois 3 semaines - il y a 6 mois 3 semainesConfiguration
@opoetasantoza Try updating it on another Laptop or PC and if that doesn't work try shorting the 2 pins to reset the chip and restore it back to the original firmware incase that's the problem.
@admin Can you post a link to the article on how to unbrick your RTL9210 chip and the ASMedia chips,I think this may help the poster as it did me one time with the same problem.
VBS MAYBE?
- opoetasantoza
il y a 6 mois 3 semainesHow to Short These Pins ?@opoetasantoza Try updating it on another Laptop or PC and if that doesn't work try shorting the 2 pins to reset the chip and restore it back to the original firmware incase that's the problem.
- opoetasantoza
How to Short These pins ?
