- CaBrAcHo83
il y a 6 mois 3 semaines
Thanks for the info but still the "Failed" message on my side🥲
try plugging it into a usb 2.0 or 3.0 port because I had a crash and I managed to update it to USB 3.2 instead of my Thunderbolt port
- opoetasantoza
My Drive dont recognise on mptool, any ideia ?
Try on a USB 2.0 port because maybe some controllers are not supported by the MPTOOL
- opoetasantoza
I tryed on old laptop and get same error
