Hello everyone,
Fdrsoft
il y a 5 mois 2 semaines
#3755
I think the included version should do it can you confirm (AS_USB4_240913_00_00_00.bin)
  • Galixte
  • Portrait de Galixte
  • regular poster
  • regular poster
il y a 5 mois 2 semaines - il y a 5 mois 2 semaines
#3757
Je refait un test après avoir vu que j'ai oublier de coché la case SSD dans les paramètres, voici avec le cache et sans .
Oui avec le dernier firmware du boitier ASM2464PD et la mode CrystalDiskMark « NVMe SSD » cela donne cela de mon côté :
  • Galixte
  • regular poster
  • regular poster
#3758
see below..
Looking at the  chipmaker’s website , there aren’t many differences:
  • The “X” version supports configuration of the four PCIe lanes to support up to four devices at once. The lanes can be configured as a single 4-lane device, two 2-lane devices, four 1-lane devices, or a 2-lane device and two 1-lane devices.
  • The “X” version can support an external power-delivery controller chip (in case the built-in one is not sufficient for the product).
These differences are important if you’re designing an enclosure, but as a user buying an enclosure, the differences shouldn’t matter.
  • Portrait de Shonk
#3759
yeah it was just me miss remembering something
Thinking ASM2464PD was ASM2464
and ASM2464PDX was ASM2464PD
my bad
  • taiduc94@gmail.com
  • Portrait de taiduc94@gmail.com
il y a 4 mois 6 jours
#3975
Happend when i tried to upgrade, and then my Maiwo k1717 only run at usb gen 3x1, speed limit to 10gbs. please help. Can not upgrade, fail all the time.
Pièces jointes :
