  • Alien Invader
  • Alien Invader's Avatar
TiX which mainboard you have ? It seems to me that you are connected to a 5Gbit port, the name for 10Gbit should be different on chipgenius as I have the same 5Gbit connection and same HIGH SPEED indication.
My screenshot is with a M2 SATA on USB 3.0 5Gbit port (Z97)
*As the 2nd image says USB 3.2 Gen1 is in fact 5Gbit so the speed you have is pretty normal. The 10Gbit ones are called 3.2 Gen2.
Last edit: 3 years 5 months ago by Alien Invader.
  • kufa
  • kufa's Avatar
For anyone who has this case, I've written an answer file that works perfectly for it.
Inateck FE2025
Inateck.cfg
Warning: Spoiler!
  • TiX
  • TiX's Avatar
Using a MSI katana gf66 notebook the mainboard is "msi MS-1584"
Thx Kufa
Very useful for those who don't know
" Using a MSI katana gf66 notebook the mainboard is "msi MS-1584" "
If your box is well connected in USB 3.2, try to see if your disk, what model is it?
Otherwise you can try to update but I don't know if that solves your problem, to see
