  • ethereal
  • ethereal's Avatar
3 years 5 months ago
Anyone has a clue if the NVME-TO-USB adapters like the 9210B can initialize the Host Memory Buffer feature of the newer NVME SSD's ?
I don't think so. The HMB is a part of the NVMe specification. The USB standards (USB mass storage and USB attached SCSI) don't include, AFAIK, any similar functionality to allow devices to access host memory. So even if adapters such as the 9210B could support HMB at the PCIe interface, they wouldn't be able to properly translate/resend those PCIe messages through the USB bus.
Regards.
Hi you have updated a part one or both at once
sinopn to restore the firmware see here
  • lazarusa
  • lazarusa's Avatar
reloading solved the problem
Good
  • eljedix
  • eljedix's Avatar
Hello everyone new member here thx all for the hard work and the info i have a unionsine carry it works well and i got it updated to last firmware no problem. got one issue cause i dint read and updated at once i dint dump my config file currently im using a oricoro one and it works well led ligths and all but i saw other people said they had unionsine carrys too. if it is not too much trouble can someone post their config dumps ?
chip
