- wade7575
3 years 1 month ago
Email has been sent let me know how thing's workout,I titled the email RTL9210 Config file.
- waldyrdias@msn.com
- User
3 years 1 month ago
Hello, I installed the configuration you sent me and unfortunately it didn't work. The ssd cannot be mounted on Macos, but on windows it works perfectly. I have a 2TB nvme ssd, that must be the problem. The brand is kingspec NX Series. It is formatted in exFAT so it can be read on macos and windows.
Thanks a lot for the help.
- User
3 years 1 month ago
The case from orico just arrived and it came with realtek 9210B as well. I tested it and the problem continues. I believe the problem is the kingspec ssd because mine from Netac works perfectly in Orico and unionsine.
3 years 1 month ago - 3 years 1 month ago
try to update the firmware of the SSD if it is available
Last edit: 3 years 1 month ago by admin.
- User
3 years 4 weeks ago
These chinese ssd don't have update. it's a kingspec.
