  • ze-bob
  • ze-bob's Avatar
3 years 1 month ago - 3 years 1 month ago
Hello to all, i have an ANYOYO M.2 USB adapter with RTL9210B, this one have a blue LED that is blinking when it works, since i updated the Firmware to V1.29.12.011122 this LED is only fixed BLUE.
Is there a way to set it to blink again ?
Thant you.
My adapter here:
www.amazon.com/gp/product/B09H6K3TTQ/ref..._image?ie=UTF8&psc=1
Last edit: 3 years 1 month ago by ze-bob.
Hi, yes if you saved your *.cfg file
Otherwise you have to edit the *.cfg file of the package and modify the Led section
www.station-drivers.com/index.php/en-us/...-1-xx?start=130#1122
You can also take another *.cfg file to compare
Here are several configuration files (cfg)
Last edit: 3 years 1 month ago by admin.
  • ze-bob
  • ze-bob's Avatar
No, i'm stupid and no save the original CFG file, i'll try another and see what hapen.
Thank you SD
EDIT: Solved with "RTL9210_VB_CG_Orico_0_Mod.cfg", big thanks !
3 years 1 month ago
Goodddddddddddddddd
The following user(s) said Thank You: ze-bob
  • Galixte
  • Galixte's Avatar
_
Salut l'équipe !
I've updated the firmware on my two USB enclosures, Sabrent EC-SNVE (RTL9210B bridge), from version 1.31.16 to 1.32.49 .
When I perform a dump, I notice that there are three new parameters:
And one modified value:
Previously (v1.32.16): IC Pkg Type: PCIE_SATA
Now (v1.32.49): IC Pkg Type: PCIE/SATA
In the RTL9210B-CG.cfg file from version 1.32.49, one of these new parameters is defined:
PERIPH_API = 1
Do you know what this parameter does?
I share my config file dedicated to SABRENT EC-SNVE: [url] share.galixte.com/index.php/s/Tonja9ZmYSg9zjJ [/url]
Last edit: 3 years 1 month ago by Galixte.
