- jumpy76
- i0ntempest
I have three AQC113 cards:
The one built into my Z790 ProArt (0x1D6A:0x94C0:0x1043:0x87F5, updated fine to 1.5.38)
A Seekswan (Chinese brand) PCIe card I got from Taobao (0x1D6A:0x14C0:0x1D6A:0x0001, will not update)
An Innodisk M.2 card (0x1D6A:0x14C0:0x1BC0:0x20E1, will not update)
The error message:
Getting four part IDs...
Read four part IDs from the device: 0x1D6A (VID), 0x14C0 (DID), 0x1D6A (SVID), 0x0001 (SDID)
Updating the clx file...
./customclx2 0x1D6A 0x14C0 0x1D6A 0x0001 updatedata.xml updated.clx
customclx2: get_xml_data() returns 69
customclx2: readBdp() returns 69
Could not find the updated firmware image: updated.clx.
is the same for both cards what will not update. I'm guessing they don't exist in the xml?
The error message:
Last edit: 2 years 3 months ago by i0ntempest.
Hi yes you have to add ls in the xml file for recognition, Shonk knows more than me
- i0ntempest
Thanks. Given the possibility of bricking the card I need to know exactly how to mod the xml files. In what section should I add those IDs (that is what firmware file to use)?
yes I understand I have the same motherboard as you and it is true that it was easier after that it is more difficult with additional cards, Shonk and more experienced
