  • White-Panda
  • White-Panda's Avatar
9 months 2 weeks ago
I see, thanks for the info.
I also notice that the Acasis TBU405M1 enclosure is cool when the PC is awake (crystal disk info 32c) but very warm when the PC is sleeping (39c when checking right after waking)
The Realtek RTL9210 chipset generates very little heat, which is why it doesn't need a heatsink. A heatsink is often designed for the hard drive, even if it's a 10GB SSD, because the SSD itself gets hot. The one that gets hotter is the Asmedia ASM2464 chipset (40GB), which requires it to be placed directly next to the case's heatsink.
  • jelb0
  • jelb0's Avatar
6 months 2 weeks ago
I've got a Fanxiang MP83 enclosure (with a LED) with a RTL9210B at firmware 1.33.81. Which MPTool Lite should I use to update it to 1.34.39.032625? I have 1.12.x, 1.15.x and 2.0.2.x. Also, I intend to follow these steps . Not sure if it's worh the risk.
Hi, there's no risk because you have the option to perform a recovery and you can use the Mptool utility, the one provided with the firmware.
However, make a backup of the configuration beforehand (*.CFG).
Recovery
  • jelb0
  • jelb0's Avatar
It worked! I've kept the 'Firmware GD' and 'Disk' sections as it was. GD version is v4.30.23.071922 (with MPTool 1.12 it would be v1.25.14.041521...)
 I've created my own Fanxiang MP83.cfg from the dump, see below. This is what MPTool Lite looks like:
U2PHY = n/a U3PHY = n/a VID = 0x0bda PID = 0x9210 MANUFACTURE = "Fanxiang" PRODUCT = "R0" SERIAL = "133810000552" SCSI_PRODUCT = "MP83            " SCSI_VENDOR = "Fanxiang" USB_SELF_PWR = n/a DISK_HOTPLUG = n/a LED = 0x01 PINMUX1 = n/a PINMUX2 = n/a U2_MAXPWR = n/a U3_MAXPWR = n/a ASPMDIS = n/a PCIE_REFCLK = n/a DISK_IPS_THRES = 0x0a SWR_1_2V = n/a EN_UPS = n/a PD = n/a CUSTOMIZED_LED = n/a SUSPEND_LED_OFF = n/a FORCE_USB_SPEED = n/a FORCE_PCIE_SPEED = n/a EN_U1U2 = n/a FORCE_USB_QUIRK = n/a FORCE_PCIE_QUIRK = 0x00040000 FAN = n/a DIS_SHOW_EMPTY_DISK = n/a FORCE_SATA_NORMAL_DMA = n/a UART_DBG_PIN = 0x05 FINGER_PRINT_EN = n/a RM_INTERNAL_RD = n/a HS_AUTO_SWITCH = n/a UART_BAUD_RATE = 0x0000e100 CUSTOMIZED_DISK_IDENTIFY = n/a HW_LED_CFG = n/a CDROM_CFG = n/a SUPPORT_HID = n/a LATE_INIT_DISK = n/a SCSI_WP_PIN = n/a SD_MMC_TYPE = n/a FORCE_PORT_TYPE = n/a BCDDEVICE = n/a SUSPEND_DISK_OFF = 0x07 SCSI_WB_PIN = n/a CUSTOMIZED_FEATURE = 0x0000000000010000 PERIPH_API = 0x01 RAID_CFG = n/a Boot Mode = Flash FW Ver = 1.33.81 FW Build Date = 2024.06.17 IC Pkg Type = PCIE UUID = n/a Disconn_ForceUSB2 = false
Last edit: 6 months 2 weeks ago by jelb0.
