2 years 1 month ago
it must have come with a bad nvram then (cfg)
2 years 1 month ago
Ofc you can i customize all of mine for the drive actually in there and its actual serial number and such
Here's one as an example
;Configure Start ;=================FW Configure================= U2PHY = 02 f4 9b e0 e1 U3PHY = 02 d4 09 00 d5 00 80 VID = 0xbda PID = 0x9210 MANUFACTURE = "Samsung" SCSI_VENDOR = "Samsung" PRODUCT = "Samsung SSD PM9A1 1TB" SCSI_PRODUCT = "SSD PM9A1 1TB" SERIAL = "S641NX0TB24240" DISK_HOTPLUG = 0x0 PINMUX1 = 0x70000 PINMUX2 = 0x0 U2_MAXPWR = 0xfa U3_MAXPWR = 0x70 ASPMDIS = 0x0 ;SUSPEND_DISK_OFF = 1 ;10 minutes of idle time will disable disk power DISK_IPS_THRES = 10 ;EN_UPS = 0x0 ;PD = 0x0 LED = 0x1 ;HW_LED_CFG = 0x0 ;CUSTOMIZED_LED is 15 bytes ;CUSTOMIZED_LED = 01 01 ;SUSPEND_LED_OFF = 0x0 ;FAN = 0x0 ;DIS_SHOW_EMPTY_DISK = 0x1 ;FORCE_SATA_NORMAL_DMA = 0x0 UART_DBG_PIN = 5 ;FINGER_PRINT_EN = n ;=================Tool Configure================= ;DISCONN_FORCE_USB2 = n FORMAT_DISK = n ;INC_SERIAL = y ;PARTITION: GPT, MBR PARTITION = "MBR" ;FORMAT: NTFS, exFAT FORMAT = "NTFS" ;LABEL max allowed - characters LABEL = "My USB"
The following user(s) said Thank You: pt83
  • pt83
  • pt83's Avatar
2 years 1 month ago
I want to add GUID is that possible? Orico Box a few years ago do have GUID but newer one doesn't have. Which is needed for my UnraidOS to accept the license linking.
[IMG
  • yasins
  • yasins's Avatar
  • User
  • User
2 years 1 month ago
Hello! Please file send to me :) E-Mail will be to sent PM
  • yasins
  • yasins's Avatar
  • User
  • User
2 years 4 weeks ago - 2 years 4 weeks ago
Good day, Is it possible to change the IC Pkg Type section of the box and get SATA feature in the box? Is such a thing possible? There is also Realtek rtl9210b-CG SATA support, which is normally found on the box., so I set the firmware to 1.33.44.  Model : M2PV-C3
************************************************************** Device : [Port4] : Realtek RTL9210B-CG #0 ************************************************************** U2PHY : n/a U3PHY : n/a VID : 0x0bda PID : 0x9210 MANUFACTURE : "Realtek" PRODUCT : "Realtek" SERIAL : "012345678909" SCSI_PRODUCT : "RTL9210B-CG     " SCSI_VENDOR : "Realtek " USB_SELF_PWR : n/a DISK_HOTPLUG : 0x00 LED : n/a PINMUX1 : 0x00000000 PINMUX2 : 0x00000000 U2_MAXPWR : 0xfa U3_MAXPWR : 0x70 ASPMDIS : 0x00 PCIE_REFCLK : n/a DISK_IPS_THRES : 0x00 SWR_1_2V : n/a EN_UPS : n/a PD : n/a CUSTOMIZED_LED : 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00  SUSPEND_LED_OFF : 0x01 FORCE_USB_SPEED : n/a FORCE_PCIE_SPEED : n/a EN_U1U2 : n/a FORCE_USB_QUIRK : n/a FORCE_PCIE_QUIRK : n/a FAN : 0x00000000 DIS_SHOW_EMPTY_DISK : n/a FORCE_SATA_NORMAL_DMA : n/a UART_DBG_PIN : 0x05 FINGER_PRINT_EN : n/a RM_INTERNAL_RD : n/a HS_AUTO_SWITCH : 0x05 UART_BAUD_RATE : n/a CUSTOMIZED_DISK_IDENTIFY : n/a HW_LED_CFG : n/a CDROM_CFG : n/a SUPPORT_HID : n/a LATE_INIT_DISK : n/a SCSI_WP_PIN : n/a SD_MMC_TYPE : n/a FORCE_PORT_TYPE : n/a BCDDEVICE : n/a SUSPEND_DISK_OFF : 0x01 SCSI_WB_PIN : n/a CUSTOMIZED_FEATURE : n/a PERIPH_API : n/a RAID_CFG : n/a Boot Mode : Flash FW Ver : 1.33.44 FW Build Date : 2024.01.18 IC Pkg Type : PCIE UUID : n/a Disconn_ForceUSB2 : false
[img
Last edit: 2 years 4 weeks ago by yasins.
