2 years 1 month ago
There is nothing special about the ORICO BM2C3-2N its just two enclosures in one shell
you have to plug it in with two cables and flash both of them with the correct cfg file
which you can get from your current firmware by pressing Dump Show Device Info in MPtool_Lite
then you just flash the latest RTL9210B_v1.33.44.011824.bin with the ORICO BM2C3-2N.cfg
you make from the Dump Show Device Info page
2 years 1 month ago
Hi, does the flash utility recognize the chipset or at least one of the two or both?
  • pt83
  • pt83's Avatar
Hi, I tried but failed.
[img
My config is as followed
U2PHY : n/a U3PHY : n/a VID : 0x0bda PID : 0x9210 MANUFACTURE : "Realtek" PRODUCT : "RTL9210" SERIAL : "712785178904" SCSI_PRODUCT : "RTL9210 NVME    " SCSI_VENDOR : "Realtek " USB_SELF_PWR : n/a DISK_HOTPLUG : n/a LED : 0x01 PINMUX1 : n/a PINMUX2 : n/a U2_MAXPWR : n/a U3_MAXPWR : n/a ASPMDIS : n/a PCIE_REFCLK : n/a DISK_IPS_THRES : n/a SWR_1_2V : n/a EN_UPS : n/a PD : n/a CUSTOMIZED_LED : n/a SUSPEND_LED_OFF : n/a FORCE_USB_SPEED : n/a FORCE_PCIE_SPEED : n/a EN_U1U2 : n/a FORCE_USB_QUIRK : n/a FORCE_PCIE_QUIRK : n/a FAN : n/a DIS_SHOW_EMPTY_DISK : n/a FORCE_SATA_NORMAL_DMA : n/a UART_DBG_PIN : 0x05 FINGER_PRINT_EN : n/a RM_INTERNAL_RD : n/a HS_AUTO_SWITCH : n/a UART_BAUD_RATE : n/a CUSTOMIZED_DISK_IDENTIFY : n/a HW_LED_CFG : n/a CDROM_CFG : n/a SUPPORT_HID : n/a LATE_INIT_DISK : n/a SCSI_WP_PIN : n/a SD_MMC_TYPE : n/a FORCE_PORT_TYPE : n/a BCDDEVICE : n/a SUSPEND_DISK_OFF : n/a SCSI_WB_PIN : n/a CUSTOMIZED_FEATURE : n/a PERIPH_API : n/a RAID_CFG : n/a Boot Mode : Flash FW Ver : 1.33.44 FW Build Date : 2024.01.18 IC Pkg Type : PCIE UUID : n/a Disconn_ForceUSB2 : false
Last edit: 2 years 1 month ago by pt83.
2 years 1 month ago
Its no good reading it now you have to read it before ever flashing it
the second one is running the goldenfirmware (safemode firmware)
as you havnt added complete info is my guess
  • pt83
  • pt83's Avatar
2 years 1 month ago
Yes but. I'm too scared to brick my box, even though I do have flashing recovery tool. I really need this because Linux doesn't accept the box with identical id which is "Realtek_RTL9210_NVME_012345678905-0:0" I need some way to make them different. Thank you!
