2 years 5 months ago
There are 3 versions of the chip
Well 1 version of the chip but 3 versions of the pcb
NVME
SATA
SATA/NVME
my guess is you ordered the NVME only version
  • lapis
  • lapis's Avatar
OK, I suppose that those item descriptions on Aliexpress can't be trusted... :-D
It was this "CoolFish M2 SSD Case NVMe SATA Dual Protocol" for a bit over 3$.
I suppose there is no way to add SATA support by firmware or some easy mod?
  • Laroldski's Avatar
@lapis If you want a great ssd enclosure for NVMe ssd's try the one in the link in black it has an RTL9210 controller the other one in grey has a JMS583 controller,their not much more money and way better built then those coolfish ones.
[url] www.aliexpress.com/item/1005006437088311...in.29.27c11802Al6Vvk [/url]
  • ole258
  • ole258's Avatar
I have bought a Lexar E300 NVME enclosure.
Here is the Dump:
Warning: Spoiler!
In comparison to most other Dumps, there are much values marked as "n/a".
For example:
U2PHY = 02 f4 9b e0 e1
U3PHY = 02 d4 09 00 d5 00 80
DISK_HOTPLUG = 0x0
PINMUX1 = 0x0
PINMUX2 = 0x700
U2_MAXPWR = 0xfa
U3_MAXPWR = 0x0
ASPMDIS = 0x0
For what are these values for?
Is it recommended to add it at the config file?
Last edit: 2 years 5 months ago by ole258.
  • sdefrwggerg
  • sdefrwggerg's Avatar
2 years 4 months ago
are you sure that´s a Realtek RTL9210/RTL9220 Chip inside?
