  • TheGiolly
  • TheGiolly's Avatar
2 years 8 months ago - 2 years 8 months ago
Hi, I bricked my Orico SSD NVMe enclosure with the RTL9210B.
I read that you can reset the flash memory connecting the 1 & 8 pin, but I do not which its the chip.
Someone can help with the pictures please?
Thx!
You need to bridge pins 1 and 8 of the UC25HQ40
Last edit: 2 years 8 months ago by TheGiolly.
  • Jþ's Avatar
IT's usually the one with the hole and the one on the other side. Although, if you already over-written the config, I don't know how to recover from that.
Could you please sump your config onnce you get it into recovery mode?
Hi, this is the dump before the failed flash.
Device : Realtek RTL9210B-CG #0
U2PHY : 02 f4 9b e0 e1
U3PHY : 02 d4 09 00 d5 00 80
PRODUCT : "RTL9210B-CG"
SERIAL : "012345679039"
SCSI_PRODUCT : "RTL9210B-CG "
CFEXPRESS : 0x00
PINMUX1 : 0x00070000
PINMUX2 : 0x00000000
PCIE_PWRCUT_THRES : 0x0a
CUSTOMIZED_LED : n/a
EFUSE :
Boot Mode : Flash NM
FW Ver : 1.23.15
FW Build Date : 2020.11.16
IC Ver : 0xa0010002
IC Pkg Type : PCIE
Disconn_ForceUSB2 : 0x00
Last edit: 2 years 8 months ago by .
  • Jþ's Avatar
Thx!
Hi, I tried but does not work.
The LED its dead also.
I will try with a solder jumper, maybe my twezzers do not contact with the pins.
Thx for the answer.
  • Jþ's Avatar
Good news!
I already save the device.
I did the bridge with a solder copper filament to the pin 1 & 8 of the UC25HQ40 and Windows 11 recognize the device after 2 seconds, then I cut the wire and proceed to the new flashing process.
I used UTHSB_MPtool_Lite v1.15.10.30417
The bin was RTL9210B_v1.32.68.062623_signed.bin
The gd RTL9210B_gd_v4.30.23.071922.bin
And the previous config file from the initial dump.
Thxs for your help!
Windows 11 still not recognize the disk inside the enclosure, that was the main reason for this proccess, I do know why...
If I use a live distro of linux I can use the disk with no problem.
  • symbios24
  • symbios24's Avatar
  • User
  • User
Hello happy new year
i have a USB 3.0 type C transparent case with Realtek rtl9201R Chip
the only problem i have is that every one minute the case goes into sleep mode very annoying im using mechanical HDD
the case chip has firmware 1.32.7 i cannot seem to find any other firmware to update it,all i want is to disable the sleep mode or set it after 100 mins for example
i dont care if its an older firmware i just want to disable the sleep timer
Any Help here???
Last edit: 2 years 8 months ago by symbios24.
