3 years 1 week ago
Hi, try running it in administrator mode or copy the content to another directory
  • TheGiolly
  • TheGiolly's Avatar
3 years 1 week ago
I moved all the files to C:\temp\ and run the software as administrator, but nothing changed.
If I disconnect the USB drive, the Configure option is set correctly but as soon as I plug the drive in, it becomes blank again.
3 years 1 week ago
try other firmwares or other *.cfg files from various packages to see if it recognizes it
  • TheGiolly
3 years 1 week ago
Ok, It was a problem with the .cfg file.
To make it work:
- Dump -> Show Device Info -> Save
- Delete first 3 lines and all the lines after the empty line towards the end
- Substitute all the ":" characters with "=" characters
- Save as .cfg and use it in UTHSB_MPtool_Lite
Hope this is useful to someone else!
The following user(s) said Thank You: cyberlan
3 years 1 week ago
Impeccable well done
