- djmaniac44
3 years 3 weeks ago - 3 years 3 weeks ago
Thanks for your information and documentation.
In the meantime I found some interesting documentation on chinese "AirChip" page (google trans) - Including some recomendation for 3 usecases (mobile data storage, WinToGo, NAS)
www-airchip-org-cn.translate.goog/index....hl=de&_x_tr_pto=wapp
(Original: www.airchip.org.cn/index.php/2022/04/18/9210abfw1298/ )
And a usefull but heated discussion about value ASPMDIS (aka "Active State Power Management Disable" ?)
forums.anandtech.com/threads/stable-nvme...572973/page-18#posts
Last edit: 3 years 3 weeks ago by djmaniac44.
The following user(s) said Thank You: xiaomantou, aktaş
- aktaş
3 years 3 weeks ago
Hello dear members. Below my message, I shared the internet address link of the external SSD box I use. The product is made OEM in China by a local company in my country. The chipset is seen as rtl9210b-cg. The product includes an adata legend 800 lite 1 tb ssd with exfat file system. The product provides full USB 3.2 gen 2 port speed. I have no problems using it on a computer or Android phones such as Xiaomi. By the way, my phone is Samsung S23 Ultra. When I connect the product to my phone and try to copy files, the connection is disconnected after almost 700 MB. Even without reformatting the product on a computer or another Android phone, it does not connect to my own phone. I tried all the firmwires posted on the forum. but I didn't get any results. What can I do?
[url] bix.com.tr/bix-bx05hd-type-c-3-1-gen2-to...m-2-ssd-disk-kutusu/ [/url]
- forum2k
3 years 2 weeks ago - 3 years 2 weeks ago
after updating to the latest firmware all ssd are not writeable, any idea how to fix this ?
I used the attached .cfg files...when flashing to higher firmware....
Chipset pic attached, seems to be:
RTL9210 N6AK5E2 GN24B
Nick
RTL9210.cfg:
VID = 0xbda
PID = 0x9210
MANUFACTURE = "Realtek"
SCSI_VENDOR = "Realtek"
PRODUCT = "RTL9210"
SCSI_PRODUCT = "RTL9210"
SERIAL = "802345978984"
DISK_IPS_THRES = 30
LED = 0x1
CUSTOMIZED_LED = 00 00
SUSPEND_DISK_OFF = 0x7
SCSI_WP_PIN = 0xc
UART_DBG_PIN = 5
PERIPH_API = 1
UART_BAUD_RATE = 57600
Nick
RTL9210.cfg:
VID = 0xbda
PID = 0x9210
PRODUCT = "RTL9210"
DISK_IPS_THRES = 30
LED = 0x1
SCSI_WP_PIN = 0xc
UART_DBG_PIN = 5
PERIPH_API = 1
Last edit: 3 years 2 weeks ago by forum2k.
write protection switch present 0xa, 0xc
SCSI_WP_PIN = 0x0
SD_MMC_TYPE = 0x0
SCSI_WP_PIN = 0x0
SD_MMC_TYPE = 0x0
Last edit: 3 years 2 weeks ago by sdefrwggerg.
- TheGiolly
3 years 1 week ago
Good afternoon,
I have an external enclousure with a Realtek RTL9210B-CG.
I downloaded firmware 1.32.87 but, when I open UTHSB_MPtool_Lite, the "Configure" option is blank and if I select "configure\RTL9210B_CG.cfg" the option stays blank.
If I click on the "Update Device" button, I get a message saying "No configure file".
How can I solve this problem?
Thank you in advance
Device : [Port20] : Realtek RTL9210B-CG #0
U2PHY : 02 f4 9b e0 e1
U3PHY : 02 d4 09 00 d5 00 80
PRODUCT : "RTL9210B-CG"
SERIAL : "012345678906"
SCSI_PRODUCT : "RTL9210B-CG "
DISK_HOTPLUG : 0x00
LED : 0x02
PINMUX1 : 0x00000000
PINMUX2 : 0x00000000
DISK_IPS_THRES : n/a
CUSTOMIZED_LED : 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00
FW Ver : 1.29.12
FW Build Date : 2022.01.11
IC Pkg Type : PCIE
