- wade7575
3 years 5 months agoHi @wade7575, @all
I think I will not get much of a difference by changing FW versions. I got the latest version installed already, and as I mentioned, I got real work copy speed of 375 MB/s over a 12 GB file.
And I also have a USB 3.2 Gen 1 port.
See also Crystal Mark below.
Thank you very much for your time
I posted the message for dreaminglife but if it helped you as well that's great.
The following user(s) said Thank You: jj
- blackbile
3 years 4 months ago
Anyone has problem with Unionsine MD202 USB-C - USB-C cable came in the package? It seems that it matters how I plug into the PC USB-C slot in one direction it works and the PC recognize it and it doesn't work if I rotate the plug by 180°
Could it caused by firmware or simply the cable (or PC) is bad?
- wade7575
3 years 4 months agoAnyone has problem with Unionsine MD202 USB-C - USB-C cable came in the package? It seems that it matters how I plug into the PC USB-C slot in one direction it works and the PC recognize it and it doesn't work if I rotate the plug by 180°
I haven't any problems with the included cables myself but I did switch to longer cables because I needed longer cables and I found that these cables work with every enclosure I have no matter what the brand where I have had problems with other cables in the past and this was a bonus switching to these cables.
These cables will also last longer because of the braid on them and will also help the wires not to break inside.
vi.aliexpress.com/item/1005004852057867....gatewayAdapt=glo2vnm
