- wade7575
3 years 3 months ago
Email has been sent let me know how thing's workout,I titled the email RTL9210 Config file.
- waldyrdias@msn.com
- User
Hello, I installed the configuration you sent me and unfortunately it didn't work. The ssd cannot be mounted on Macos, but on windows it works perfectly. I have a 2TB nvme ssd, that must be the problem. The brand is kingspec NX Series. It is formatted in exFAT so it can be read on macos and windows.
Thanks a lot for the help.
- User
The case from orico just arrived and it came with realtek 9210B as well. I tested it and the problem continues. I believe the problem is the kingspec ssd because mine from Netac works perfectly in Orico and unionsine.
try to update the firmware of the SSD if it is available
Last edit: 3 years 3 months ago by admin.
- User
These chinese ssd don't have update. it's a kingspec.
