Be careful, as some external PCI-E cards (probably not Rev 3) are not compatible, so read the messages carefully.
Here is the command for firmware recovery:
flashUpdate2.exe --reflash xxxxxxxx.clx
AQC113 Firmware Flashing and Recovery Notes · GitHub
Otherwise, I haven't had any problems with my Z890 ProArt so far.
Definitely do a clean install of your old firmware.
  • misal1337
  • Portrait de misal1337
  • Poster
  • Poster
Connected to device 'NDISIO:14C0-00E:00.0'
Error: RBL failed to start after issuing reset
Failed load UpdateAgent
Unable to flash
Also this error
flashupdate2 -i
flashUpdate2 x86_64-w64-mingw32-4.10-126-g5407c89
FourPartIDs:0x0000:0x0000:0x0000:0x0000
The chipset is recognized; if so, try with a different firmware or the last one that worked.
Note: Use the latest drivers, version 3.1.11.0.
  • misal1337
  • Poster
  • Poster
Same error with other firmware. Tried it by booting into Hiren Boot PE. Windows can recognise the card and HWID shows the correct 4 parts. But updater doesn’t see. Only sees 0000 0000 0000 0000. It cannot reset the card as well.
In CMD, launch the command flashUpdate2.exe -h; you will have options to force the update.
