For:
VID=0x1D6A, DID=0x04C0 (AQC-113)
VID=0x1D6A, DID=0x14C0 (AQC113C)
VID=0x1D6A, DID=0x94C0 (AQC113CS)
Firmware For Windows
Release note:
- Sets hysteresis to 50 mV.
Feel free to leave a comment
Les utilisateur(s) suivant ont remercié: jumpy76
  • misal1337
  • Portrait de misal1337
  • Poster
  • Poster
Les utilisateur(s) suivant ont remercié: admin, jumpy76
  • jumpy76
  • Portrait de jumpy76
Thank you for your answer.
Thank you!
Edit: where did you write your ID? In the configuration section for deviceSupported, and...?
  • misal1337
  • Poster
  • Poster
Yes there.
  • jumpy76
I get this error, any idea?
[img
