Intel Management Engine Interface (MEI/AMT) Version 241x.xxx
  • oemuser
  • Portrait de oemuser
  • Poster
  • Poster
Re: Intel Management Engine Interface (MEI/AMT) Version 241x.xxx
il y a 10 mois 1 semaine - il y a 10 mois 1 semaine
#2937
Are you sure about 5th Gen?
I've seen that the latest MEI driver v2406.5.5.0 installed on 5th gen system with pre-integrated ISO
Last time i checked old MEi (HECI) HW  device IDs were not present in latest packs, do please confirm your needs and related ID's in both drivers, newer and older.
Take a look also here  section: D1. Old Intel MEI Drivers and Software
ME 7-8-9 series (9 aka 5th Gen CPU)
  • SM-003
  • Portrait de SM-003
  • Moderator Global
  • Moderator Global
il y a 9 mois 2 semaines - il y a 9 mois 2 semaines
#3045
The 5th gen system I was referring is not mine so I couldn't be able to check on that just yet. But I'll surely try to check at the earliest, and will post/update over here.
On another note,
what's the last version for MEI Ext? The last version posted here is 2334.5.1.0 here . As I checked, it's the same version for both MEI driver as well MEI Ext. So, question is,
whether MEI driver & MEi extension are the same thing?  or both are different component but embedded into the same INF and CAT file, for by the same device by sharing the same HWID (that is pci\ven_8086&dev_a360 in my case)
& the same version?
Unlike the other MEI software components i.e. DAL, iCLS, etc, I've not seen this MEI extension anywhere in the device manager/software components sections.
System H/W Specifications
#3046
I think the MEI Ext and for the operation of the HSA module
  • SM-003
  • Moderator Global
  • Moderator Global
#3047
@ oemuser
I checked two old systems with 5th gen CPU
Dell Inspiron 5558 (5th Gen i7)
PCI\VEN_8086&DEV_9CBA&SUBSYS_06AE1028&REV_03
PCI\VEN_8086&DEV_9CBA&CC_078000
Dell Inspiron 3558 (5th Gen i3)
PCI\VEN_8086&DEV_9CBA&SUBSYS_06B01028&REV_03
this PCI\VEN_8086&DEV_9CBA is present inside the heci.inf of the latest MEI driver version 2406.5.5.0 (8th Feb 24)
& installed in both of the i5 systems.
Les utilisateur(s) suivant ont remercié: duttyend, oemuser
  • SM-003
  • Moderator Global
  • Moderator Global
#3048
what HSA module you're referring? I haven't seen any HSA component for intel MEI?
And what's the last version released for this MEI ext?
Temps de génération de la page : 0.086 secondes
