Intel Management Engine Interface (MEI/AMT) Version 241x.xxx
il y a 10 mois 3 semaines - il y a 10 mois 3 semaines
#2875
MEI: 02/08/2024,2406.5.5.0
MEI Ext:
SOL: 04/18/2023,2316.5.0.0
SOL LMS Ext: 04/18/2023,2316.5.0.0
WIMAN: 03/22/2024,2412.80.252.0
WIMAN Ext: 03/22/2024,2412.80.252.0
LMS:  02/21/2024,2316.5.1.12 New
ICLS: 03/08/2024,1.72.189.0 New
DAL: 07/11/2023,1.44.2023.0710
MEWMIP: 02/21/2024,2408.5.4.0 New
MSS (HSA) : 2350.5.3.0
WHQL: oui (22/03/24)
Officiel: non
Pour: Windows 10/11 (64bits)
Donwload
www.station-drivers.com/index.php/en/com...241x.xxx/lang,en-gb/
Les utilisateur(s) suivant ont remercié: grimson, duttyend, fikotr74
  • SM-003
  • Portrait de SM-003
  • Moderator Global
  • Moderator Global
Re: Intel Management Engine Interface (MEI/AMT) Version 241x.xxx
il y a 10 mois 1 semaine - il y a 10 mois 1 semaine
#2933
This latest version of MEI driver v2406.5.5.0 (Feb 24) is supported from intel 5th Gen CPU onwards.
What's the last released MEI Driver for older gen CPU up to 4th Gen?
Is it  11.0.0.1160 (July-15)
or 11.0.5.1189 (March 16)
or 11.7.0.1057 (Nov 17)
I am creating a Win ISO integrating all the required basic drivers for my older (2nd, 3rd & 4th gen based) systems
therefore looking for the last released MEI driver for the older gen CPUs up to 4th gen
System H/W Specifications
  • oemuser
  • Portrait de oemuser
  • Poster
  • Poster
#2934
For 3rd, 4th and 5th GEN the latest is the 11.7.0.1057, others versions are from WU and OEM releases or packages version numbers, the HECI driver itself is always the 11.7.0.1057.
[Intel.ntamd64.10.0]
; DisplayName               Section           DeviceId
%TEE_DeviceDesc%=TEE_DDI_W10_x64, PCI\VEN_8086&DEV_8C3A   ;ME9.1  - HSW/LPT-H
%TEE_DeviceDesc%=TEE_DDI_W10_x64, PCI\VEN_8086&DEV_9C3A   ;ME9.5  - HSW/LPT-LP
%TEE_DeviceDesc%=TEE_DDI_W10_x64, PCI\VEN_8086&DEV_8D3A   ;ME9.1  - HSW/WBG
%TEE_DeviceDesc%=TEE_DDI_W10_x64, PCI\VEN_8086&DEV_9CBA   ;ME10.x - BDW/WPT-LP
%TEE_DeviceDesc%=TEE_DDI_W10_x64, PCI\VEN_8086&DEV_8CBA   ;ME9.1  - BDW/LPT-H
  • SM-003
  • Moderator Global
  • Moderator Global
#2935
Are you sure about 5th Gen?
I've seen that the latest MEI driver v2406.5.5.0 installed on 5th gen system with pre-integrated ISO
  • CoVaL_78
  • Portrait de CoVaL_78
#2936
Dokładnie. Mam laptop ASUS X555LJ  z procesorem INTEL CORE I5-5200U, czyli 5 generacja i wszystko działa dobrze.
