  • rebootbee
  • Portrait de rebootbee
il y a 9 mois 2 semaines
Hi that ORICO USB4 cable 1 meter looks super thick, have you been using it for a long time and how has the stability been overall? Any issues with detection, freezing or crashing or suddenly cutting out with no detection etc
I found 0.5 metre Thunderbolt 4/5 certified cables from cable matters and others to still be unstable, they may work on the 4-5 time but on 6-7th they can not detect the drive or become unstable, they were thick but not as thick as that orico from looks.
Mine is over a year old, no problems at all, perfect
Les utilisateur(s) suivant ont remercié: rebootbee
  • misal1337
  • Portrait de misal1337
  • Poster
  • Poster
il y a 9 mois 6 jours - il y a 9 mois 6 jours
Hello, I have ShuoLe ASM2464 NVMe enclosure from Aliexpress. I inserted Crucial P3 2TB Plus into it. Works damn good. But if I connect it to USB 4 port of my Asus X870E ProArt motherboard, Rufus cannot detect the external drive. It only gets detected when connected to USB 3.2 20G or 10G ports. I checked the USB drives option in Rufus.
Secondly, when I try to boot my drive with Ventoy installed and Strelec Boot PE iso, it boots into it but fails to mount the drive containing recovery apps when plugged into USB 4 port. This issue does not happen on USB 3.2 20G or 10G ports.
Tried upgrading as well as downgrading ASM2464 frimware. I also tried downgrading BIOS, changing cables. But this is USB4 port problem.
Any solution?
www.banggood.in/ShuoLe-SL-TP4001-USB4-M_...ehouse=CN&ID=6287832
il y a 9 mois 5 jours - il y a 9 mois 5 jours
Hi, have you updated the firmware of the USB4 (Asmedia) port + port PD ?
ASUS 4242 and PD-GX Firmware Windows Update Tool
ProArt X870E-CREATOR WIFI|Cartes mères|ASUS France
  • Stasiz
  • Portrait de Stasiz
  • poster 5
  • poster 5
Hi, try changing the U4 mode:
Les utilisateur(s) suivant ont remercié: misal1337, rebootbee
