il y a 4 ans 5 jours
Galixte
Réponse de  Galixte  sur le sujet  NVME USB drives Realtek RTL9210B / RTL9210 Firmware v1.23.9
1.27.24 firmware is compatible with both, 9210 and 9210B.
It’s available here:  station-drivers.com/index.php/en/drivers...-1.27.24/lang,en-gb/
  Galixte
This page: [url][/url]   www.station-drivers.com/index.php/fr-ca/...own/5236/lang,fr-ca/    indicates it’s about the 1.27.25 firmware revision but it’s 1.27.5 version, dedicated to RTL9210A chipset only.
  Galixte
Odpoveď od  Galixte  na tému  NVME USB drives Realtek RTL9210
Indeed, but there is a file useful to be updated for your USB Realtek 9210a enclosure:
gdfw\UTGDFW_A_v4.22.27.081220.bin
For information, in the ZIP archive file from 1.29.12 firmware, there is two GD firmwares (  secondary firmware  ) :
- file: UTGDFW_A_v4.22.27.081220.bin (12.08.2020) dedicated to Realtek 9210 (also known as RTL9210A) chipset ;
- file: UTGDFW_B_v4.22.27.081220.bin (12.08.2020) dedicated to Realtek  RTL9210B-CG  chipset
So, I think you can update only the GD firmware.
sdefrwggerg napísal:
what do your damp settings look like ? You can try with v1.29.12
Sabrent use:
LED = 0x1
;CUSTOMIZED_LED is 15 bytes
CUSTOMIZED_LED = 0a 01
;SUSPEND_LED_OFF = 0x0
DIS_SHOW_EMPTY_DISK = 0x1
DISK_IPS_THRES = 1
AFAIK, these settings mean:
  • Code:
    LED = 0x1
    - LED setting: When the USB enclosure is connected to the USB port of the machine, the LED is powered to ON. 0x1 value means: 1 (Setting activated), while 0x0 value means: 0 (Setting disabled)
  • Code:
    - This line is only a commentary to detail the content value for this setting. It needs 15 bytes for the setting value.
  • Code:
    - CUSTOMIZED_LED setting: It permit to customize the led color. I think when the setting value is 0a 01 it means blue color, while when the value is 22 00 it means white color.
  • Code:
    - SUSPEND_LED_OFF setting: Activated this setting permits to power off the LED when the Low Power Mode is activated, not when software ejected. 0x0 value means  0 (Setting disabled), while 0x1 value means: 1 (Setting activated)  Source  .
  • Code:
    - DIS_SHOW_EMPTY_DISK setting: When the USB enclosure has no SSD while it’s connected to the machine, this setting activated permits to see the USB enclosure on Windows. For example, it’s usefull to update the firmware.whithout alterate the SSD.  Source  (take a look at the PDF file in this Zip archive file).
  • Code:
    DISK_IPS_THRES = 1
    - DISK_IPS_THRES settings: xxx minutes of idle time will disable disk power. 1 value means 1 minute, while 10 value means 10 minutes of idle time after disabling the SSD power.
  • Code:
    - This character must be placed before the setting (To comment the setting). When commented the default value for this setting is applied by the machine OS/Bios. Example
    ;LED = 0x1
mixmaster57
Hi all
I updated my SSD Enclosure to version 1.29.12
Since this update the activity LED no longer flashes.
The SSD Enclosure is however detected and it works fine.
The brand is MOKIN. (link :    www.mokinglobal.com/product/63.html  )
Anyone have a solution to this problem?
