  • Absent
il y a 1 an 11 mois
for me the problem seems to come from the disk cache if I'm not mistaken have you updated the disk firmware if it exists
  • AOnurY
  • Portrait de AOnurY
  • Membre
  • Membre
il y a 1 an 11 mois
Disable antivirus and try again
  • yasins
  • Portrait de yasins
  • Membre
  • Membre
il y a 1 an 11 mois
Onur hocam selamlar, RTL9210 chipli bir box almıştınız. Aliexpress üzerinden aldıysanız kapıda herhangi bir vergi ücret vs. verdiniz mi ? Bende almayı düşünüyorum ancak vergi çıkar mı diye merak ettim ?
  • AOnurY
  • Membre
  • Membre
il y a 1 an 11 mois
DM den yazdım dostum.
  • chaosdeus
  • Portrait de chaosdeus
il y a 1 an 11 mois
Yes. I did a quick check by open BG3 from the ssd after I updated the firmware. Only few minutes after you posted the latest firmware 1.33.98.090324. My only antivirus is Windows Defender and while updating it was really quiet.
Do you mean that if problem exists after firmware updated, it could come from disk cache?
Thanks for reply.
Temps de génération de la page : 0.030 secondes
