7 months 3 weeks ago - 7 months 3 weeks agoFor:
VID=0x1D6A, DID=0x04C0 (AQC-113)
VID=0x1D6A, DID=0x14C0 (AQC113C)
VID=0x1D6A, DID=0x94C0 (AQC113CS)
Firmware For Windows
Release note:
- Sets hysteresis to 50 mV.
Feel free to leave a comment
- misal1337
- Poster
Last edit: 7 months 3 weeks ago by misal1337.
The following user(s) said Thank You: admin, jumpy76
- jumpy76
Thank you for your answer.
Thank you!
Edit: where did you write your ID? In the configuration section for deviceSupported, and...?
Thank you!
Last edit: 7 months 3 weeks ago by jumpy76.
- misal1337
- Poster
- jumpy76
7 months 3 weeks agoPlease Connexion or Create an account to join the conversation.
