  • Valivolf
  • Valivolf's Avatar
Re: NVME USB drives Realtek RTL9210
1 year 10 months ago
Hello. I have an enclosure adapter and an SSDSCKKW128G8 drive. My disk is not initialized in the system. I tried to install different configurations, but nothing helps. This disk is not visible on all devices. And most likely this adapter too. Is there anything we can do about it?
  • Laroldski's Avatar
I understand what your saying about the ssd not being initialized,just to be clear did you try and use Windows to initialized the ssd,I know a lot of people think that a hard drive and ssd will always work as soon as they are put into a pc or enclosure and that is true for some prebuilt hard drives and ssd's.
When you say that the ssd is not visible on all device's,are you using it on some Windows PC's and also with Apple PC's what exactly do you mean,I can assure you that it won't be the configure file that's the problem it could be the partition scheme,for example is partition scheme MBR or GPT was the ssd formatted in Fat32 Fat or NTFS that would most likely be the problem.
Take a look at this video and please tell me if you did what's in the video.
www.youtube.com/watch?v=ySm_ERcVUlk&t=2s
  • Valivolf
  • Valivolf's Avatar
I can't do it like in the video. I have an incorrect function output. Even the disk volume is not displayed. And the disk itself works on all three laptops that I had, but it was no longer displayed on the computer, not in the bios, not in windows. And the adapter doesn't seem to see it either, as does the computer.
  • Fridira
  • Fridira's Avatar
1 year 7 months ago
Hello everyone. I have a problem.
When I connect my enclosure to usb 3.0(5 gbps) about 40s my disk usage up to 100% and after down to 0% and read speed show 35-38mb/s. When I transfer little or large file speed always 35-38mb/s. Also I think I have problem with a temperature control. Because in do not working ssd time my ssd temp 45 degree. Usually in a notebook it's about 30-32 no more.
Installed rom: realtek_rtl9210B_fw (Version 1.33.98.090324)
controller: rtl9210B
Used port: usb 3.1 gen 1 (5 gbps)
Enclosure model: ShuoLe TP06-AC for nvme ssd
My ssd: wd sn530
1 year 7 months ago
Hi, I think that because you connected it to a USB 3.1 port, the rate is normal. However, check that the disk is in good contact with the case via thermal paste because any SSD heats up without a radiator.
