Bonjour étrange qu’il soit si vieux le firmware sinon vous avez la possibilité de revenir à l’origine avec cette manipulation sinon. pour mettre à jour avec le fichier de configuration d’origine ou par défaut celui du paquet
Station-Drivers - Firmware recovery from USB 3.2/NVMe enclosures
Last edit: 2 years 3 months ago by admin.
- Calbrac
Hi everyone, I would like to know if anyone has had the experience or encountered the RTL9210C driver. I have read the entire post from top to bottom and I can't find any reference to it. I have also downloaded all the available firmwares without being able to find the missing .bin. I have also had no luck searching the web. Maybe it is a re-written or fake chip?
I have started this search because I can't get it to connect at a speed other than USB2.1. I have already changed all the cables (I even bought a Lenovo cable certified as 10mbps) and I have tried on several computers without success.
I would appreciate any information in advance. Thanks
- D-One
To enable things from the firmware .cfg do we need to remove the semicolon? Is it the symbol for a code comment?
For example to enable 10min idle do I have to remove the ";" from the 2nd line below?
;10 minutes of idle time will disable pcie power
;PCIE_PWRCUT_THRES = 0xa
- TheGiolly
Yes, you need to remove the semicolon
