1 year 5 months ago
Or you have the reason why you try nothing, it will always be better
I took a dump of the factory firmware today with a programmer to find out the exact firmware in the NICGIGA REV2.0 GiGaPlus Rev 2.0 cards
so i know the exact firmware i should use
Its AQC113-DirtyWake_Bx-1.5.38_bdp_aqsign.clx
AQC113-DirtyWake_Bx-1.5.42_bdp_aqsign.clx is the correct update
Im going to use AQC113-DirtyWake_Bx_ASPM_Enabled-1.5.42_bdp_aqsign.clx
to enable ASPM though
Its PCIE 4.0 x 4 not 3.0 x2
Loaded bundle: 1.5.38
edit
update.bat seems to cause no connection
something wrong with making updated.clx? due to xml being wrong for the card?
flashing like so is fine
flashupdate2 --reflash ATL2-8.0.1_AGENT_sign.CLX AQC113-DirtyWake_Bx_ASPM_Enabled-1.5.42_bdp_aqsign.clx
kickstart2
rem ******************** done restoring factory NICGIGA firmware sleep or shutdown the pc ********************
  • lupusbytes
  • lupusbytes's Avatar
driver: atlantic
version: 6.14.7-gentoo
firmware-version: 1.3.24
After the update it showed
driver: atlantic
firmware-version: 1.3.33
After rebooting I had no network.
  • The lights are on in the network interface
  • The operating system recognizes the NIC and thinks it's active; enp13s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
  • The switch recognizes a link
  • No packets can be sent or received. tcpdump only shows "unanswered" ARP traffic from the interface
Sometimes the firmware has to be modified for your device
thats what updatedata.xml is for its a database of what to flash and what needs modifying
depending on the card version / firmware being flashed
find a firmware that update.bat/startprg.bat correctly works on your card's id
pc has to be fully powered down after flash not just shut down (pull the cord and try powering with no power to disipate caps)
a good place to start is use the flasher package admin used on his asus cards as that had his four part id and updated his fine
here's admin doing his see it making a custom update for his four part id
  • lupusbytes
Wow. Can't believe I missed this part about physically pulling the power.
I ran the 1.5.42 update from the Hirens Boot CD environment, without modifying any files, which then installed AQC113-Antigua_Bx-1.5.42_bdp_aqsign.clx
Then I shutdown and pulled the power.
Upon starting the system I didn't get the "atlantic: Boot code hanged" that I saw yesterday on 1.5.39 and 1.5.42.
Then I could see the NIC again in the OS with ethtool:
driver: atlantic
firmware-version: 1.5.42
and it could actually send and receive packets!
I then tried to run iperf3 at full 10G speed over LAN again, but unfortunately it crapped itself after 3 minutes, like it usually did.
I'm very happy that it's not "bricked" anymore, but sad that this firmware adventure didn't bring any improvements to the stability for me.
@Shonk
Do you use any custom settings on the NIC, like disabling EEE, flow control and so on to make it stable?
Last edit: 1 year 3 months ago by lupusbytes. Reason: typo and wrong file mentioned
