1 year 8 months ago
With Regards to aspm i have it disabled in the bios on all of my machines but the card is reporting the following with your 1.3.33
Active State Power Management (ASPM) Support: L0s and L1
Active State Power Management (ASPM) Status: Disabled
1 year 8 months agothat means secure boot is enalbed i thinkit tells me Failed to initialize HW Interface
i had it earlier rebooted and disabled secure boot and it was fine then
- hu4567
1 year 8 months agodid see your edit a bit to latecan you release a zip with every file edited and ready to go with a command
e.g. ini's edited and it will patch the clx on the fly
i dont want to miss anything
and maybe a txt file in there saying what was changed in what file
actually i think i know everything you done
i will make one and try it myself after dinner
here is a zip file: www.dropbox.com/scl/fi/5cr41qmlw91c5j2h2...avr&st=vfgn4pch&dl=0
diff -Naur org/flashUpdateScript.ps1 mod/flashUpdateScript.ps1
--- org/flashUpdateScript.ps1 2023-06-12 11:37:50.000000000 +0200
+++ mod/flashUpdateScript.ps1 2024-12-16 20:10:50.760076400 +0100
@@ -29,7 +29,7 @@
If (Test-Path -Path ./updated.clx ) {
Write-Host "Flashing the device with updated.clx..."
- ./flashUpdate2 --update ATL2-8.0.1_agent_SIGN.clx updated.clx
+ ./flashUpdate2 --reflash ATL2-8.0.1_agent_SIGN.clx updated.clx
Write-Host "Kickstarting new firmware..."
./kickstart2
diff -Naur org/updatedata.xml mod/updatedata.xml
--- org/updatedata.xml 2023-06-12 11:37:50.000000000 +0200
+++ mod/updatedata.xml 2024-12-16 20:10:26.680859000 +0100
@@ -155,4 +155,13 @@
<exprom>True</exprom>
<image>AQC113-Antigua_Bx-1.3.33_bdp_aqsign.clx</image>
</bdp>
+ <bdp id="15">
+ <hwids>
+ <pciid vid="1d6a" did="14c0" sdid="0001" svid="1d6a" />
+ </hwids>
+ <mac>01000c0040000000000000000100000002000c00000300003ddb9ca1ffffffff</mac>
+ <phy>0301040200e4030003001cc482b1ffff1dc482b1ffff1ec40100ffff</phy>
+ <exprom>True</exprom>
+ <image>AQC113-DirtyWake_Bx_ASPM_Enabled-1.3.33_bdp_aqsign.clx</image>
+ </bdp>
</bdpDatabase>
The following user(s) said Thank You: MrCrowX, Shonk
1 year 8 months ago
Fenvi Factory 1.3.21 firmware aspm status
Connected to device '0000-0A:00.0'
Chip reset completed (boot from flash). Time: 60 ms
Loaded MAC FW Version: 1.0.113
Loaded bundle: 1.3.21
Active State Power Management (ASPM) Support: None
L0s Exit Latency: 2 - 4 us
L1 Exit Latency: 32 - 64 us
Maximum Payload Size Supported: 512 bytes
Maximum Payload Size: 256 bytes
You where right it was not erasing the chip before flash that was causing issues on the newpeak.net/Fenvi/Nicgiga card when updating
I have been testing different firmware's all evening they all flash and work with no issues that i can see
your mileage may vary though
You just have to run update.bat from a command prompt then shutdown to reload the firmware fully
I ended up making individual flashers only for fenvi cards and cleaned out all of the excess files
wake on lan from a powered off state doesnt work on the stock fenvi 1.3.21 which i think is AQC113-Antigua_Bx-1.3.21_bdp_aqsign.clx
it also doesnt work with AQC113-DirtyWake_Bx_ASPM_Enabled-1.x.xx_bdp_aqsign.clx
so im going to stick with AQC113-Antigua_Bx-1.x.xx_bdp_aqsign.clx
Here's a copy with my Fenvi factory backup included incase there are problems with newer firmware's
mega.nz/file/V2ZRGZ6Q#kdhnKiErNcAFIh6ajM...sYOIu3w0ii4GEhwrZXNs
www.youtube.com/watch?v=Xni3WfLX-X4
Of Interest
when i dumped the firmware of both cards in april 2024 to fix the first card
I dumped the first card that was bad but never bothered trimming the file or testing it in any way
I did this earlier
just flashing with flashupdate2 --reflash ATL2-8.0.1_AGENT_sign.CLX bad_card_good_trim.clx (Factory.bat)
put it back to how it was before fixing it (no link as i had done some further messing with the firmware)
running the dump through customclx2 + reflashing with Update.bat
after a powerdown and back up the card seems fine
so you can fix a bad flashed card without any further firmware
if your firmware is doing code 10 in windows
and Error: MAC firmware is not started. Reset status = 0x15000000
you should be able to fully fix it just by flashupdate2 --reflash ATL2-8.0.1_AGENT_sign.CLX your_dump_trim.clx then shutdown
though i think flashing
flashupdate2 --reflash ATL2-8.0.1_AGENT_sign.CLX AQC113-Fenvi_Factory_Dump_1.3.21_bdp_aqsign.clx (my factory dump) then power down
is the only surefire way to ensure all variables are restored to the card before progressing to a newer firmware
and is what i did after i finished testing before moving on to 1.5.42
Of Interest
I did this earlier
