2 years 4 months ago
I presume you edited updatedata.xml wrong
Here's 1.3.36 with updatedata.xml edited and 1.5.38 files added from station-drivers
It worked fine on my Z690 Aorus Master
mega.nz/file/8zpkAD6T#epbVRFBUAjbvXDftUo...qmHFUiDnthsCnd57PGCU
I didnt add in support for Fenvi/Newpeak/NicGiga as im still waiting for working updatedata.xml settings for them
I have a problem the CMD page opens the same as powershell and closes immediately, I think it's a problem loading a file or security, I'm going to search
right click startprg.bat run as administrator?
open a command prompt in the folder
flashupdate2 -i
and tell me your four part ids i will check if support is in updatedata.xml for your card
Last edit: 2 years 4 months ago by Shonk.
it tells me Failed to initialize HW Interface
that means it cant detect your card
asus must use a weird id on it
