2 years 11 months ago
Here is my Id Code of my AX200 160Mhz
  • SM-003
  • SM-003's Avatar
  • Moderator Global
  • Moderator Global
Dated September 6, 2023
Download:
This package ain;t compatible with AX211
Warning: Spoiler!
I have no way to test it regardless what the INF says, I still need to learn how to read INFs but usually MoKiChU knows what devices are supported since I am sure he checked the INFs first or else he would have said it supported everything else too before he even posted it originally.  Is there a tool somewhere that can extract the Device ID's and such from the INFs as I am sure no one is going to go read each INF slowly and then copy and paste the lines so there must be some way you and others are doing it.
You can open the INF in simple notepad like I did as you can see in the attached screenshot in my earlier post
About the latest v23.0.5.7 Wifi driver
even this one is also not fully supported with AX211 Wifi-6E, it can be only installed via forcefeeding the INF, although the wifi is working after installation unlike the earlier release v23.0.0.18 where it was not working.
Intel is really messing around with their latest wifi drivers of late. So, I will rather wait for a better & stable 23x build releasing in the upcoming days.
System H/W Specifications
Last edit: 2 years 11 months ago by SM-003.
  • atplsx
  • atplsx's Avatar
Intel Wireless WiFi
DriverVer = 09/06/2023,23.0.5.7
Direct Link
download.windowsupdate.com/d/msdownload/...c695bfd24e27cd0f.cab
Last edit: 2 years 11 months ago by atplsx.
The following user(s) said Thank You: contra, duttyend
  • SM-003
  • SM-003's Avatar
  • Moderator Global
  • Moderator Global
Intel Wireless WiFi
It's the same driver version v23.0.5.7 that admin post here  3 days ago.
Just the Driver only [CAB] package from Microsoft Update Catalog website.
  • atplsx
  • atplsx's Avatar
Intel Wireless WiFi
I don't expect to be appreciated anyway, but if you want, I won't share new things and keep them to myself. The aim here is to help people
Why do I sort through and download so many files and look at their contents like a cow every day? My goal is to help people.
The following user(s) said Thank You: duttyend,
