- SM-003
- Moderator Global
2 years 11 months ago - 2 years 11 months agoThis package ain;t compatible with AX211Intel PROSet Wireless WiFi Drivers v23.0.5.7 WHQL with many thanks to MoKiChU
Dated September 6, 2023
Download:
Last edit: 2 years 11 months ago by SM-003.
- fademind
- poster 5
Intel WIFI drivers 23.0.0.18 works for me.
ibb.co/5RGh7kQ
HWID
ibb.co/5RGh7kQ
HWID
PCI\VEN_8086&DEV_43F0&SUBSYS_00748086&REV_11
- SM-003
- Moderator Global
2 years 11 months ago - 2 years 11 months agoIntel WIFI drivers 23.0.0.18 works for me.
ibb.co/5RGh7kQ
HWIDCode:PCI\VEN_8086&DEV_43F0&SUBSYS_00748086&REV_11
neither the HW id you shared is enlisted inside the INF
Just realised, you're talking about different driver version 23.0.0.18, not the v23.0.5.7
Intel PROSET/Wireless Wifi software Version 23.0.5.7 WHQL Complet
No problems, everything works normally
The following user(s) said Thank You: duttyend,
- User
2 years 11 months ago - 2 years 11 months agoI have no way to test it regardless what the INF says, I still need to learn how to read INFs but usually MoKiChU knows what devices are supported since I am sure he checked the INFs first or else he would have said it supported everything else too before he even posted it originally. Is there a tool somewhere that can extract the Device ID's and such from the INFs as I am sure no one is going to go read each INF slowly and then copy and paste the lines so there must be some way you and others are doing it.This package ain;t compatible with AX211Intel PROSet Wireless WiFi Drivers v23.0.5.7 WHQL with many thanks to MoKiChU
Download:
Last edit: 2 years 11 months ago by .
