- Vitaliy
Hello.
I got on Amazon "Midautoo I225-V Network Card"
PCI\VEN_8086&DEV_15F3&REV_01
I try to update firmware with no success
That what I have
EEUPDATE v5.38.10.00
1 2 00 00 8086-15F3 Intel(R) Ethernet Controller I225-V
1: EEPROM Image Version: 1.36
C:\Temp>EEUPDATEW64e.exe /nic=1 /DUMP
1: Writing EEPROM image to file '1CFD0876A607.eep'...Done.
NO .bin created.
C:\Temp>EEUPDATEW64e.exe /nic=1 /d NVM\FXVL_15F3_V_1MB_1.89.bin
1: Image size larger than flash size, aborting!
Driver date 2/9/2023
Driver version 1.1.4.38
That what I have
NO .bin created.
Last edit: 1 year 8 months ago by Vitaliy.
- Online
1 year 8 months agoConfiguration
- Vitaliy
1 year 8 months ago
Hi.
Is here anything I can do with this card except of returning it?
- Online
1 year 8 months ago
why it doesn't work ?
- Vitaliy
It shows 1Gb max. Much slower then onboard 1Gb and periodicly stops working.(No light). Only restart helps.
It has "P25Q16H Ultra Low Power, 16M-bit Serial Multi I/O Flash Memory" on board. Why it does not want to read and write it?
