  • Jodragons
  • Jodragons's Avatar
1 year 10 months ago
#1112
Bonjour,
j'ai mis à jour sur ma carte ASUS ROG STRIX B550-F GAMING (WI-FI) et tout c'est bien passé.
La procédure de mise à jour est très bien détaillée, en 1min c'est fait.
Vraiment merci.
  • Online
#1113
Salut,
Merci pour le retour
  • Tadeo
  • Tadeo's Avatar
1 year 9 months ago
#1179
On ASUS STRIX Z-590A when trying to flash this firmware I'm getting this error
Aborting installation because driver already exists. Run install /y to override!
To Exit,
Check EEPROM Image information:
LAN is Non-vPro SKU
EEUPDATE v5.38.10.00
NIC Bus Dev Fun Vendor-Device  Branding string
  1   6  00  00   8086-15F3    Intel(R) Ethernet Controller (3) I225-V
Writing SHARED FLASH.  PLEASE DO NOT INTERRUPT THIS PROCESS.
  1:  Shared Flash image update FAILED! Pointers in Shadow RAM are corrupted
[uninstall.bat] Removing iQVW Driver - SUCCESS
The Computer will shut down to take effect after pressing any key, then you can press power button to turn on it, thanks!
Press any key to continue . . .
i7-11700K / ASUS Z590-A Strix/ Crucial Ballistix 64GB 3200 CL16 / XFX AMD RX 6800 16GB/ 2x SSD 970 Evo Plus 1TB and 2TB / PSU: NZXT C850 / DELL S3422DWG, Windows 11 22H2
  • Online
1 year 9 months ago
#1180
it is possible that there is a problem with the drivers, check that you have the latest drivers, then install the drivers from the pack and relaunch to see
unless there is i225 protection in the setup
The following user(s) said Thank You: Tadeo
  • Tadeo
  • Tadeo's Avatar
1 year 9 months ago
#1183
ok, It's done. Image was written successfully. Thanks.
