- Online
1 year 9 months agoConfiguration
- Districtor
1 year 8 months ago - 1 year 3 months ago
Asus ROG MAXIMUS XIII HERO 2 x Intel I225-V
The first NIC updated fine from 1.68, the second NIC update hung for over an hour, so i had to terminate via Task Manager.
Now, if I try to flash 1.89 I get the message: Shared Flash image update FAILED! Pointers in Shadow RAM are corrupted.
The same message with the backup dump.
nvmupdatew64e.exe -i -l yourlogname.log for the second NIC:
[00:007:00:00]: Intel(R) Ethernet Controller (3) I225-V
Vendor : 8086
Device : 15F3
Subvendor : 8086
Subdevice : 0000
Revision : 3
LAN MAC : 000000000000
Alt MAC : 000000000000
SAN MAC : 000000000000
ETrackId : 00000000
SerialNumber : F02F74FFFFCB1xxx
NVM Version : N/A(N/A)
PBA : N/A
VPD status : Corrupted
VPD size : 0
checksum : Invalid
EEUPDATE:
2: EEPROM Image Version: Unversioned
Device Manager:
This device cannot start. (Code 10)
STATUS_DEVICE_POWER_FAILURE
NIC Driver:
2.1.3.3
Now I know, the second NIC is most likely bricked, but has anyone any ideas how to fix this?
Vendor : 8086
Device : 15F3
Subvendor : 8086
Subdevice : 0000
Revision : 3
ETrackId : 00000000
PBA : N/A
VPD size : 0
checksum : Invalid
EEUPDATE:
Device Manager:
NIC Driver:
2.1.3.3
Last edit: 1 year 3 months ago by Districtor.
- Districtor
1 year 8 months ago
Nevermind, fixed it by using nvmupdatew64e with the -f (force) command.
- EDU5K
hi i have asus b550-e win 10 21h2 19044.3086 Intel I225-V Rev 2 driver 1.1.4.38 NVM version of the NIC is 1.69(1.45) can i update without problems?
Last edit: 1 year 8 months ago by EDU5K.
- Online
1 year 8 months ago
Hi, yes no problem normally, make a backup of the firmware before
