Intel Management Engine Interface (MEI/AMT) Version 2519.8.3.0
Re: Intel Management Engine Interface (MEI/AMT) Version 2519.8.3.0
1 year 2 months ago
Apparently the problem was solved with these new drivers, now my PC goes into standby mode without any problem   (for now )
  • SM-003
  • SM-003's Avatar
  • Moderator Global
  • Moderator Global
Since iCLS version 1.75.121.0 (4th Nov 2024) and onwards,
the specific HWID SWC\PROVIDER_INTEL_COMPONENT_ICLSCLIENT_ES_ONLY is no longer present in the iCLS INF file iclsClient.inf.
As a result, all the 12th Gen+ newer systems that rely on this HWID can no longer be updated to the latest iCLS versions.
The last version that still includes this ES_ONLY HWID was 1.74.210.0.
Starting with 1.75.121.0, and continuing through 1.76.95.0, and the latest 1.77.4.0, only the generic HWID SWC\PROVIDER_INTEL_COMPONENT_ICLSCLIENT remains.
Anyone know what changed or any reason behind this removal?
System H/W Specifications
Last edit: 1 year 2 months ago by SM-003.
  • TurboTacho
  • TurboTacho's Avatar
1 year 2 months ago
www.intel.com/content/www/us/en/content-...ewer-processors.html
I think this is the reason why it's removed. I'm not too technical about this, but it seems like the answer to your question.
The following user(s) said Thank You: THEBOSS619, duttyend, SM-003, fikotr74
  • SM-003
  • SM-003's Avatar
  • Moderator Global
  • Moderator Global
That's the exact official statement regarding the query.
Thanks.
The following user(s) said Thank You: duttyend, TurboTacho
