Intel Management Engine Interface (MEI/AMT) Version 2519.8.3.0
Release note 📌Resolves an issue with Wi-Fi networks not being found.- Resolves an issue where the system takes too long to enter S3 with certain network cards.
www.station-drivers.com/index.php/en/com...19.8.3.0/lang,en-gb/
The following user(s) said Thank You: duttyend, fikotr74, geneticsystem2013
Re: Intel Management Engine Interface (MEI/AMT) Version 2519.8.3.0
1 year 2 months ago
I'm experiencing a recurring issue with the standby mode (release note) that was causing the PC to have trouble getting to idle.
I'll confirm if the issue has been resolved for me.
  • Dynastar
  • Dynastar's Avatar
  • Moderator Global
  • Moderator Global
Morning bro
hope you're fine but can't download it :
Internal Server ErrorThe server encountered an internal error or misconfiguration and was unable to complete your request.Please contact the server administrator at root@localhost to inform them of the time this error occurred, and the actions you performed just before this error.More information about this error may be available in the server error log.
Would/Could you try, please, to fix it ?
Thanks and have a nice day.
Kind regards
IT / Staff member / Donator / Global moderator on / 5G alternative solution.
Last edit: 1 year 2 months ago by Dynastar.
  • Fernando
  • Fernando's Avatar
1 year 2 months ago
The "Server Error" was caused by a typo within the link.
Here is the corrected link:  www.station-drivers.com/download/intel/m...ion-drivers.com).zip
Regards
Dieter
The following user(s) said Thank You: Tom, THEBOSS619, duttyend, fikotr74, oemuser, geneticsystem2013
1 year 2 months ago
Sorry, Thx Fernando,
link Fixed
