VIA Labs VL716 - USB3.1 to SATA 6Gb/s Bridge Controller firmware
- ikerrg
What about a new thread for the VL716 chipset? There are already firmware updates in StationDrivers, but nobody seems to be commenting on that.
www.station-drivers.com/index.php/en-us/...3.x-SATA/lang,en-us/
Official site: www.via-labs.com/product_show.php?id=68
Regards.
Regards.
Last edit: 1 year 11 months ago by admin.
Re: VIA Labs VL716 - USB3.1 to SATA 6Gb/s Bridge Controller firmware
Yes the VL-716 and less currently used
Station-Drivers - Comparatif 8 Boitiers Externes NVMe/USB 3.x
- ikerrg
I was trying to update my ineo enclosure (VL716 chipset) using several of the firmware updates in station drivers, but none of them worked with my enclosure. It is correctly detected, but the firmware update fails. I think it is not bricked yet!
it also depends on the firmware version
- ikerrg
When an SSD is connected to this chipset, it is not correctly recognised by Windows as an SSD (for defrag purposes). That does not happen with the Realtek chipset. Hence why I was expecting to fix it with an update. There are many enclosures that have the VL716-Q4 chip (including Orico, inneo, etc). Sadly, I could not find how to make it work with my enclosure.
