hdd2 VIA Labs VL716 - USB3.1 to SATA 6Gb/s Bridge Controller firmware
Re: VIA Labs VL716 - USB3.1 to SATA 6Gb/s Bridge Controller firmware
1 year 11 months ago
#875
You have to see the configuration file which sometimes includes the IDs code to check if it is the same as yours
