  • Julia
  • Julia's Avatar
8 months 3 weeks ago - 8 months 3 weeks ago
#3150
I successfully upgraded the firmware on an Orico M2PAC3-G20 with an ASM2364 controller to 210901910000, but not via included tools and configs in this forum.
The included settings files in this thread did not work for me, the error incompatibility of firmware was popping up.
I prepared config file and flasher and instruction:
drive.google.com/file/d/1t0jRxgI9dtXNOAd...G5e/view?usp=sharing
Last edit: 8 months 3 weeks ago by Julia.
#3151
Thx  Daviteusz
The following user(s) said Thank You: Julia
#3158
the exe has the same crc32
and the ini is standard
all you have done is added a readme stating what i said to do here in the forum
you just needed to select the firmware file thats why you where getting an error
Last edit: 8 months 3 weeks ago by Shonk.
  • Julia
  • Julia's Avatar
#3160
I was choosing firmware and it just didn't work for me, I tried many times.
Maybe some option in the config matters or something, since the exe files are the same.
Or maybe because of the idle timer, because mine originally had this:
FF FF FF FF 4C 17 64 23 00 01 CF FF 02 FF 5A BD
And the program sees it as unknown.
#3181
No Problems here
I have another Samget coming from aliexpress fingers crossed it has a newer firmware..
