11 months 2 weeks ago - 11 months 2 weeks ago
Odd your serial number is AAAABBBB006E
I have three of these all from different sellers and they all had AAAABBBB0003
Thats the only diff
if you want to flash it just change the serial to AAAABBBB006E and 10 Mins
and it will match
36 45 is hex for 6E
66 is a hash
Thats the only diff
and it will match
36 45 is hex for 6E
66 is a hash
Last edit: 11 months 2 weeks ago by Shonk.
- spike_V_sky
11 months 2 weeks agoHow can I correctly identify the Vendor ID, Product ID, and Device Revision?
Are the relative path used in the FW and Preload fields correct or do you need absolute path?
The only difference of your Nvram is your serial number is AAAABBBB006E
so it's 174C 2362 0100
but if you want to confirm you can see it here
The path's are fine if there is a problem it will say so when you click update
All you need to do is Click the Padlock password = asmedia
Change the serial number to AAAABBBB006E
Idle Timer 10 Mins
Idle Timer 10 Mins
- LemonLover
9 months 4 days ago
Hi everyone,
I'm hoping someone here can help me with this.
My ASM2364 ORCIO Hub, M2PVC3-G20 ( www.amazon.com/dp/B08P1B5FQ9 ), won't be recognized by MPtool. I've tried all the versions from both here and usbdev.ru ( www.usbdev.ru/files/asmedia/asm2360mptool/ ). I'm not understanding what the problem is, as it is correctly recognized by Windows 10 on both of my laptops, the drive connected shows up fine on CrystalDiskInfo and ASM FW reader ( www.usbdev.ru/files/asmedia/asmfwreader/ ) reads and dumps the firmware fine.
@Shonk if you have any advice I'd greatly appreciate it. (I don't think mentioning works on this forum
9 months 3 days ago - 9 months 2 days ago
With Windows 11 23H2 or an antivirus, there is security which prevents the recognition of certain update utilities, I think you tried in administrator mode
For me it works without problem
Last edit: 9 months 2 days ago by admin.
