  • spike_V_sky
  • spike_V_sky's Avatar
1 year 5 days ago
#2665
@Shonk
hi, i would ask you if the Samget Enclosure you bought has an fan inside to dissipation, the description from aliexpress is not clear ( it.aliexpress.com/item/1005006372210563....gatewayAdapt=glo2ita )
Can you confirm if is works fine in term of heat dissipation and hasconnection/disconnetion issue in windows system ? Can really reach 20GBps ?
thank
1 year 5 days ago
#2667
You can see there is no fan with the images i posted of it taken apart
I have two plugged in 24/7 and havnt had any issues
on Z690/Z790 it works just fine at 20Gbps on Ryzen you roll the dice with that bad USB implementation
  • spike_V_sky
1 year 3 days ago - 11 months 4 weeks ago
#2675
@Shonk
hi,
In your post you explain about "It was simple to clone the NVRAM", When is relevant to clone the NVRAM ?
VID
PID
Serial Number
EP0 M.String
EP0 P.String
T10 M.String
T10 P.String
where do you find these value to set the ini config file ?
For example if  i just would dump my original firmware for backup and restore/flashing, is NVRAM clone required ?
Last edit: 11 months 4 weeks ago by spike_V_sky.
  • spike_V_sky
#2728
@Shonk
I received the samget with the ASM2364 controller.
I dumped my firmware, removed the 130 bytes and the padding at the end.
I compared my final firmware with yours and it doesn't match, I found that at the end of the file there is 4B 27 00 00 00 00 as a difference.
in fact if I delete this value, my firmware is the same as the one you posted
[img
 - have you idea what is this value ? ( 4B 27 00 00 00 00 )
 -  I dumped the firmware with nvme inside the enclouser, maybe be the issue ? edit: same result without the nvme inside the enclouser ......
Last edit: 11 months 3 weeks ago by spike_V_sky.
#2769
thats where a checksum of the nvram + firmware goes after you flash it
if you open say AS_PCIE_201012_91_00_00.bin you can see exactly where you should trim upto
Last edit: 11 months 3 weeks ago by Shonk.
